What model of Orion tr are you using. Those Unit come in two flavors converter, charger.
The charger would behave as you are expecting.
On the other end the converter is a fix voltage power supply. If the battery voltage it is connected to is lower than Its preset, the unit will try to push the maximum current it can until it stops on overload. This is what you seem to be experiencing. is you read the data sheet, it says the maximum Current for the 15A unit is 20A.
For that model, max output current at nominal voltage (24v) is 25 amps. 25 amps x 24 volts = 600 watts. 600 watts / 12 volts = 50 amps. Plus, there are some efficiency taxes in there.
Input and output will derate as the unit heats up.
I experience something similar with my 12|12-30 Orion: I'll see output up around 40 amps for a short period of time when the unit first starts up.
Do you have a "smart" alternator? Is it turning down voltage output during this time?
Please post screencaps of your Engine Shutdown Detection and Input Voltage Lockout settings. If set correctly, the Engine Shutdown Detection routine should automatically derate the charger's output as voltage from the alternator drops so as to keep the charger from turning off.
Those max currents are for short time periods. How long before the cut out occurs?
Are you charging LiFePO4 batteries? I don't see this behaviour using the same unit on a 200AH lead carbon setup. But also I don't have a smart alternator.
Orion-Tr Smart Dc to DC Charger, Alternator Victron Energy
__________
Orion-Tr Smart DC-DC Charger Isolated 12 / 24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Datasheet
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Online Manual
__________
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Datasheet
__________
27 People are following this question.
