What is the settings and there meanings for NZ grid codes what is the standard settings, could they cause current overloads issues?
You can download and install VE.config for free.
In VE.config you can use "Fake target with full options" to see all settings you can change.
https://www.victronenergy.com/support-and-downloads/software
About the meaning of this settings you should ask a local electrician.
Hi
I need to know from Victron how they designed to work i know all about VE config and have used it for a number of years etc.
Victron have a white paper on it?
I am a Electronics engineer and Electrician.
Regards
Rob D
NZ
21 People are following this question.
