Al avatar image
Al asked
Will the Battery Balancers work across 2 x 24v Strings?
Would the Battery Balancer work across the two parallel 24v strings, or does it only work across 12v strings?
I will soon replace my current 24v bank with a 48v bank (2v cells) and plan to turn it into 2 x 24v parallel strings.
The datasheet doesn't show my scenario, but unless it needs a 12v supply on one of the leads I think it may work?
With the Battery Balancer leads:
24+ on one strings +
0v on other strings +
Common on combined -
Would that work?
Battery Balancer
The Battery Balancer is designed to balance two 12V batteries like it is shown in the manual.
If you build a 48V system and want to balance the batteries you have to make four 12V strings and use 3 balancer.
Al avatar image
Al answered ·
Ok thanks, so they will only work for 12v strings, I don't want to make a 48v system, that's the problem, I want to turn it into a 24v system: 2 x 24v parallel strings, and it seems like the balancers can't balance these two stings, only the blocks of 12v, which won't remedy the problem of one 24v sting having a voltage differential in relation to the other.
