heraktitus avatar image
heraktitus asked
Field Test on PV Romania: Problem ?
This month there is too much problem on the PV field test. As seen on the image Mono, Split, Poly production is reasonable but Perc is total failure.
Because of this problems it is hard to believe Total Solar Yield field is correct or not ?
I think there is a data integration problem .
Maybe resetting it for this time period and starting over can be more helpful.
Monthly Periods can be more sensible
Also if you supply monthly total stats for past months.
This is a good real life study one of a kind hope it continues.
In my opinion. Thnks. Victron.
AGM Battery
