Today the remote console on my site isn't working, having done so for a year without fail. I believe the IP of the VRM relay server was changed last night - and we don't have any white or black lists in place. Can this be fixed quickly please?
I should have said that the VRM portal itself is OK and communicating with the CCGX, as it is updating regularly.
Hi @anguswbrown,
i cannot confirm a problem in general here. Do you have access to the network, or is it a remote site with no access?
In case you have access, please check if the IP (84.22.107.120) is accessible from your network.
Also, the old IP (77.72.145.194) should still be working.
A reboot of your CCGX might help here.
Regards,
Markus
It's a remote site. It has an EasySolar with a separate GSM modem connected by Ethernet cable. There is no other network there. I can visit it later today.
Hi; and update @anguswbrown his issue has been solved.
Indeed it related to the IP change; my apologies for that Angus. Something went wrong that should not have gone wrong.
EDIT: in Angus his case it was fixed by rebooting the Venus device. In any other cases that should not be necessary.
5 People are following this question.
