My BMV-712 was working correctly, when I took my Motorhome in for engine work, now main Voltage reads.04 and starter voltage is correct. They did not remove the battery that I can tell, but did do some welding.
suggest that you look at the fuse thats in the battery sense wire that goes to the main battery
In reviewing the wiring setup , I do not find a fuse in the line from the main battery to the shunt.
22 People are following this question.
VRM Battery history [ BMV-712 Smart] widget - "Time since last full charge" with wrong value
What happens when BMV712 sees charging beyond 100% SOC?
BMV 712 partially clear history data
bmv 712 wiring for 48v with mid point
BMV 712 not reseting SOC to 100% even after MPPT 15/75 has reached fully 100% SOC
