I have a battery bank consisting of 8 Trojan T105's. They are wired in 4 pairs, series-parallel giving a 12v output. Is there a Victron Battery Balancer that would work with this configuration?
No, the Battery Balancer is only available for 24V systems.
True 24v systems I am following to see if anyone has any alternative balancing equipment..all I can say to try and help is check out victron wiring unlimited pdf for the best way to wire your bank
22 People are following this question.
