Mark Maritz avatar image
Mark Maritz asked
Orion Tr Smart 12/12 18A
I tested my newly installed Orion yesterday and all was good. I then disconnected the alternative battery (after switching off vehicle) and found the Connect App still displays an output on the circuit even with no battery present (when I start the vehicle again) - NO 2nd battery connected.
Is this correct? Does the Orion not detect a no alternative battery present and just continue sending power?
Thanks
orion-tr smart
Mark Maritz avatar image Mark Maritz commented ·
Any feedback please ;)
tg1 avatar image
tg1 answered ·
Well current wouldn't actually flow without a second battery or load connected to the output.
Is there any other load connected to the output of the Orion? If so, the Orion will be acting a s a power supply and providing current to the load.
If not, I would suggest either a firmware update or a reset to default and try again.
Mark Maritz answered ·
Thanks @TG1
When no load is connected to the output I still see 14.2 V on the output... I was expecting 0V
I have the latest firmware and also done a reset already.
Regards
Mark
tg1 avatar image tg1 commented ·
Does the output voltage match the input voltage? So you see 14.2v on the input side as well?
Mark Maritz avatar image Mark Maritz tg1 commented ·
Yes.
