peterwolff avatar image
peterwolff asked
Pylontech disappeared from system
Hi, i have a multiplus 2 3000gx with on the ac in 2 APsystems micro inverters and a pylontech 2,4Kw battery. All working fine until yesterday and the pylontech does not appear in the system any more. The battery monitor is now set ad the multiplus (as no other found anymore in setup).
Battery is at 100 % and not discharging.
Its a grid connected ESS system. What could have happend?
Pylontech
@peterwolff
It is most likely a communication break. Check your cables?
If not a full power cycle and reboot may work?
Paul B avatar image Paul B commented ·
have you got the can bus terminators installed, one at the start and one at the end of the cable run. thats if you are using canbus that is.
