baraduke avatar image
baraduke asked
Problème with ORION 12-12 18A
Hi everybody
My Orion can’t charge if I put charge voltage in setting
When battery is empty , I have to start charge at 12v and raise raise raise etc 12,8v , 12,9 etc
To reach maximum capacity charge of Orion can be , but -if I put too much , the charger cut immediately
And I have to lower the voltage ...
Example
If batterie is at 40% I have to select 12,8v max
At 70% I have to select 13,3v
At 80% .... 13,8v
Etc
Etc
I cannot set 13,8 at 40% the charger immediately cut and never charge
It’s stupid , how to set this charger ?????
if I set 12,8v the output current is too low and don’t use the possibility of charger ,
And at 70% the charger don’t cut but charge is too low
Help please
orion-tr smart
