powerlust avatar image
powerlust asked
Victron Multiplus Compact Inverter 24V/1600VA/230V with Pylontech UP2500
Hi
Can you please provide me with wiring diagrams for connecting the Multiplus Compact Inverter 24V/1600VA/230V with Pylontech UP2500? We would like to have a capacity of ~4kWH so it would required 2x UP2500. Please also provide inverter settings for the inverter.
Thanks in advance
Pylontech
JohnC avatar image
JohnC answered ·
powerlust avatar image powerlust commented ·
Hi, thank you. I am only looking to connect 2x UP2500 batteries. Is a GX device required or can I get away without one?
If I do need a GX device, can you please recommend the cheapest one? It will be inside a case not accessible to the user and all that I need it to do is work with the batteries ie. none of the additional functionality is required.
I have seen the list here https://www.victronenergy.com/live/venus-os:start. Based on web pricing, it looks like the Venus is the best fit followed by the Cerbo.
Thank you
JohnC avatar image JohnC ♦ powerlust commented ·
It might be possible to go without a GX, but wouldn't be supported by Victron, and maybe not Pylon either.
The Venus GX would be cheaper than a Cerbo, but not by much. A RaspberryPi loaded with VenusOS might/should work if cash is really an issue.
Locked away, eh? Perfect for a GX box with an ethernet cable - throw away the key and monitor/control it all via LAN, or from the other side of the world via the (free) VRM portal.
The GX isn't just an 'adaptor', it's far, far more than that..
