rjo71342 avatar image
rjo71342 asked
looking for help 3 phase and home plus bus
i am looking at converting my home and business to full solar and wind power. But i but i need some major power for bus fleet 3 buses and soon 2 cybertruck (tri motor) (180*est kwh each) and based on buses using 446 kwh x 3. each charge needs to be at 100 kw/hr each. Plus 360 kwh at charge rate of 50 kw/hr per charger, plus home usage 25kw/day and garage(bus maintenance) using 70kw/day (7am-5pm)(10hrs) so need a discharge rate of approx 400 kw/hr mostly in off peak time 10pm - 5am and 12kw/hr during daylight hours so my estimates say i need 3000 kwh/ 450 kw battery. could you size up a system with 2 wind turbines and solar array plus battery with a option for 2 extra generating sources i.e. GENSET &/ hydrogen
system design
