giampaolo avatar image
giampaolo asked
Battery Balancers behaviour. Should there be an alarm?
Hi
I have a question concerning the behavior of three battery balancers I have connected to my batteries like in the enclosed picture.
I have seen that the green light turns on on all the balancers , then with a deviation of more than 50 mV the orange led of the balancer in the middle turns on while the others are off.
I also noticed that with a deviation of more than 500 mV there is no alarm on the balancers. Is this behavior normal or maybe there is something wrong with the balancers or connections?
Regards.
Battery Balancer
@Giampaolo
There is a also a voltage trigger level. So it will only balance once your batteries have hit that level. Is the 500mv happening out of the trigger range? Check the datasheet.
https://www.victronenergy.com/batteries/battery-balancer
Also a little demo page to show you how it works.
giampaolo answered ·
Now the balancer seems to be working properly. With a deviation of more than 500 mV there is an alarm and it also starts balancing the batteries after a deviation of 200 mv. Probably now I understand that only the balancer in the middle works because the imbalance is between the second and third battery in the bench.
