Earl avatar image
Earl asked
BlueSolar Charger MPPT150/85
Hi Victron Team,
Equipment details below :
*Inverter Model : MultiPlus 48V/5000VA/70A
Inverter Serial No. : HQ1419CAGKJ
SW ver. : 2624415
FW ver. : 421
*Product : Color Control GX
FW ver. : v2.20~50
*Product : BMV-702
FW ver. : 3.05
Product : BlueSolar Charger MPPT 150/85 (VE.Can) - (2 units)
FW ver. : 2.05
We've been using the ESS for almost 1-1/2 month now. Is the below screen display label (HUB-1) normal when using the ESS ?
MPPT ControllersESS
Hi; yes that’s normal. Rather than ‘Hub-1’ it means that the charger is controlled externally. We should/will change that.
Note that your CCGX is running a beta version; are you sure you want to do that? I recommend to not do that and set it to run on official releases.
And, using VRM, update the BMV.
https://www.victronenergy.com/live/vrm_portal:remote-firmware-update
Earl avatar image
Earl answered ·
Thanks, Mvader.
No, it was not meant to run on beta version.
Do you have the link for v2.2 ? I'm seeing only the 2.18 version.
Planning to update the fw via SD card on site.
Ty
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
