markus avatar image
markus asked
What Is The Maximum Acceptable Midpoint Voltage Deviation in a Victron 48V AGM Battery Bank?
I have a Battery Bank of 4 brand new Victron 90Ah AGM Deep Cycle Batteries connected in serial for 48V. They are charged primarily by a Victron MPPT.
I get an error everyday from Venus (BMV702), stating that the Midpoint Deviation exceeds 3.4%.
Is this OK? What is the maximum acceptable midpoint deviation in a 48V Victron AGM Battery Bank?
Thanks,
Markus
BMV Battery MonitorAGM Battery
markus avatar image
markus answered ·
Maybe someone can advise here please:
.) Is it a must to use Battery Balancers in a serial AGM Battery Bank?
.) Should I do equalisation charge on new Batteries?
.) what is the maximum acceptable midpoint deviation?
I have double checked:
.) Battery connections
.) Fuses of measurement wires (bad contact) to BMV
My first intention was to wait a few weeks, and so this gets better from alone, but that seems not to be the case.
As I said, the Batteries are brand new.
Thanks for help,
Markus
neoneddy avatar image
neoneddy answered ·
a 3.4% deviation is .7v or so, but all it's saying is more than 3.4%.. it could be much more. I'd do an equalization charge for sure. I'd also take a multi-meter and log the voltage of each battery. Possibly charging each one separately to get them to a known good state.
I stumbled onto this thread by trying to find what was an acceptable deviation. I just ran an equalization charge with my multiplus and just added my midpoint lead o the BMV. I'm at .2% (13.74 and 13.69) deviation on my 24v bank of 46v golf cart batteries.
markus avatar image markus ♦♦ commented ·
Hi neoneddy, thank you for answering. It seems that I was a bit too nervous on this. It now seems to get better from alone. It was never more than 3.5, these days it is at 2 to 2.4.
I will watch this further on and will report :o)
I will also do an equalisation charge, next time I'm on the site.
When do you have the .2 deviation on your golf cart batteries? At floating stage?
Thanks,
Markus
neoneddy answered ·
I was just coming down from Equalization then... as of right now it's at .1 13.81 and 13.8
ezra avatar image
ezra answered ·
Where you able to figure this out Markus? Same situation.
@ezra Hi, yes. This settled down from itself. I was too impatient with the new batteries.
I should have charged them all completely full, before deploying them.
