peter-vddriessche avatar image
peter-vddriessche asked
How to use ModbusTCP over WAN
Hello, I have a CCGX and want to read registers remotely using Modbus. I can read registers when I am linked to the local modem using Wifi (I found the IP address to be used for the ModbusTCP message in the 'Settings/Ethernet' of the console).
But I also want to do it over the internet.
The CCGX is connected to the internet with a modem and I have enabled 'port forwarding' (of port 502 which we need) on the internet-modem.
But which IP address should I use to send the message?
Do I use the IP address of the internet modem? And what if that is not a fixed IP address?
The VRM portal has no problem with this (so even if the IP address changes, it manages to find it). Can I see the IP address somewhere in the VRM portal?
Thx
Peter
Modbus TCP
trip-tracks avatar image
trip-tracks answered ·
You will need to use the public ip address (the private address is not visible outside your LAN)
You will need a static ip address or use a forwarder for your dynamic address from a service provider like noip (https://www.noip.com)
sandebs avatar image
sandebs answered ·
Hi Peter, did you find a solution to this problem?
I am trying to do the same thing in order to get access to an ESS at a remote location, so I am not connected to the LAN but want to connect over internet and communicate using modbusTCP.
How did you manage to read registers remotely?
Thank you
Sander
