ispookie666 avatar image
ispookie666 asked
Limit charge current ESS
System - Venus GX, Multiplus II 3000VA
I have set the charge current to 30A(rather than 32A) - I have tried to change the charge power in ESS to a lower value, but any change has not had an effect (eg: when I dropped the charge power to say 500W, it still charges at 30A roughly 1650W).
Battery - Li Ion
Multiplus-IIESS
solarhack avatar image
solarhack answered ·
Hi
You can set the charge current on the Venus device (Settings>>DVCC). It defaults to 50A but can go down to 1A. If you need to limit charging to 500W on a 48V system that would be around 8 to 10A
DVCC must be on and you also need to check the settings in your VE Configuration and ensure you have selected "overwritten by remote".
You should also look at the following posts
https://community.victronenergy.com/questions/31629/multiplus-charge-current-limit.html
https://community.victronenergy.com/questions/53913/how-to-limit-charge-current-in-the-system-with-old.html
I hope that helps
ispookie666 avatar image ispookie666 commented ·
Tried it - no joy.
Paul B avatar image
Paul B answered ·
another way to adjust the MAX charger power you can do this in the VE config program a MK3 is required
Yes, I'm able to use VE config. I thought ESS would be a bit easier to manage this
PeterM avatar image
PeterM answered ·
The ESS also can limit charge current/power - not sure which limit applied when - the VEConfig ( current ) on or the one in ESS ( power ) . Can some please explain the order of applicibility
