Can someone explain what this "blocked" mean?
Most likely you have a Mk3 plugged into the Multi. Unplug the Mk3....
You right, I have it pluged into the multi, but how I am to use VictronConnect, to see local devices, without MK3?
Also, can this "bocked" be a reason for holes in the graphs on VRM?
VictronConnect or VEconfig (<- in my opinion the better tool for programming) you only need for the programming after that you have to disconnect.
To monitor the Multi you can than use the GX device.
Ok, how can I see the vitals of my system without MK3 if Internet is disconnected?
The VRM and Remote Console are accessible through Internet.
Am I missing something?
The holes in the graphs on VRM are the result of me connecting MK3 to VE Bus?
Ok, I just noticed that the Remote Control is running of the LAN so Internet is not needed.
Hello @MarekP, you would want to use a VE.bus Smart Dongle.
https://www.victronenergy.com/accessories/ve-bus-smart-dongle
Best regards,
Rob
The holes are visible here
28 People are following this question.
