gary123 avatar image
gary123 asked
Replace Sure Power Isolator model 1202
I am replacing a Sure Power model 1202, which has failed, with a Victron 120-2AC .
The Sure Power unit does not have compensation conections but the Victron does.
For a straight swap can I simply connect the inputs and outputs as per the current Sure Power unit and make no connection to the Victron's compensation connections? In other words, simply not use the Victron's compensation connections?
isolators
