blaxland avatar image
blaxland asked
Bluesolar mppt 100/50 output limit
Hi I am looking to install a Bluesolar 100/50 with bluetooth dongle with 2 x 300w Jinko panels. Just wondering if the output is limited to 50amps or is there the possibility of a fuse blowing if the input spikes for any reason and tries to exceed 50amps on the output. Thank you
MPPT Controllers
wkirby avatar image
wkirby answered ·
The output is limited to 50A. Even if you put too much PV power in to the MPPT, it will be limited to 50A output.
JohnC avatar image
JohnC answered ·
Hi. Rest easy, it'll be fine.
The only way you could break it is to exceed the 100V input limit. If you series-wire the panels, just check the Voc rating from the sticker on the back. Might be 40V or so, so pretty safe to do that. Cold weather could increase that a little, but that'd be a fair margin to install that way.
If you had 3x of those panels you'd have to parallel-wire them. Into 12V that'd be ok too.
