is not possible to read excel file "Modbus-TCP register list", please where we can get it??
Hi @JORGE GONZALEZ,
The Modbus-TCP register list available here. I just downloaded it and opened it myself and it is working.
You can also see the available devices and addresses on the unit itself, as described here in the Modbus TCP manual.
Hello Guy Stewart,
Can you help me understand if following two registers (MODBUS TCP) provide the same information?
com.victronenergy.battery | Low voltage alarm | 268 | uint16 | 1 | 0 to 65535 | /Alarms/LowVoltage |
com.victronenergy.vebus | Low battery alarm L3 | 53 | uint16 | 1 | 0 to 65535 | /Alarms/L3/LowBattery |
one comes from a battery monitor / BMS, and the other comes from ve.bus device (inverter), specifically the L3 inverter. there is also a general alarm I think. please look them up.
looking for the Modbus-TCP register list the download link is not valid
Hi @Trenton,
I just tested it myself then and it worked? The file downloaded and I was able to view it.
The link sends you an email but the link does not work?
Does anyone have a direct download link?
Hi @alexsmith2k,
I have just tested it and it works for me?
Can you try manually copying the link and pasting it into your browser to see if that works, it might be some pop-up blocker that is preventing it.
Does it give you an error message of any kind?
Hi Guy,
Worked like a charm when I copied the link directly to the browser, how embarrassing, thanks for your help.
as a previous user that tried to download this document which I did eventually figure out
it is kind of cryptic to get to, but you do need a email that you can send the link to for whatever reason there is not a direct link nor is there anything on the web site stating that a valid email is needed even the picture provided there is no real mention to send a link to a email until after you figured it out
the extra hoops to jump through to get to the documents needed should be laid out better and clear
if you click on the link it should prompt you to put in a email address I had to switch browsers to get that prompt so make sure you are getting prompted to enter a email address
i have a second EM24 configured as "ac load" with ID 31 for a heat pump.
In the console of the cerbo gx i can see all values of the meter.
Now i want to read out the values via openhab. The registers 2600 and following with ID 31 cause an error.
How do i get the data?
Thanks
Stefan
You have to get it from register 3900 and onwards instead for com.victronenergy.acload.*.
31 People are following this question.
