ajfeather avatar image
ajfeather asked
Fitting Skylla Control CE unit
I am connecting a Skylla Control ce unit to a titan 48/50 charger but the ce unit only came with a diagram for different attachments. I assume the SKC diagram is the correct one and the 6 terminals are not showing any description. The diagram has 2x current control,led on ,led boost, led float and ground. I assume the 2x current control are the ones to use but do not want to damage the unit if I connect to the wrong one
charge controller compatibility
