jroux avatar image
jroux asked
MQTT topic for "PV Charger" Power on CCGX (remote control)
Hi, I have a EasySolar II GX 250/70 - 3000. I am reading the MQTT successfully for other display purposes of performance of an EES setup. Right - bottom on this is "PV Charger" with watts.
the closest topic I could find to read that is /solarcharger/273/Yield/Power, but it reads about ~33W higher. than what is shown on the screen of the CCGX remote console. Anybody got an idea of the right topic for that value?
MQTT
solarhack avatar image
solarhack answered ·
Hi
There are a few options. I'm not sure which value the display reads for its information but you can get a full list of MQTT paths
here: https://github.com/victronenergy/venus/wiki/dbus
I've listed a few possibilities:
com.victronenergy.solarcharger/Dc/Pv/Power      <- Total output power for all connected chargers (Watts)com.victronenergy.system/Yield/Power      <- Actual input power (Watts)
  • Another factor to consider is the screen may not be updated at the same rate as the MQTT events are published
  • The Inverter consumes around 33W of power so the difference may be that
Hope that helps
