Phil avatar image
Phil asked
Connect BMV712 via NO/COM/NC ports on back to Progressive Dynamics 9160ALV remote cutoff port
I need to utilize 2 of the ports on the 712 to connect to "PD Remote Shutdown Module SPDLRM1", which is installed in a "PD 6160ALV converter", in order to shutdown Lithium battery charging when battery bank reaches full SOC. I cannot find any documentation on which ports to use. Also need direction with setting the "#11 Relay Mode" in conjunction with the "#16 SOC Relay" & "#17 Clear SOC Relay". in order to accomplish this function. Any information, documentation, and direction would be appreciated!
BMV Battery Monitor
