Not charging correctly and has discharged from 100% soc to 0% within 5 min. Generator catches it before it switches the quattro off and will recover to 100% within 10 Min. no warnings and battery temp around 14-16oC
Hi Paul,
Have you run through all the troubleshooting steps here in the BYD manual:
Is the site on VRM, and if so, do you mind if I have a look?
5 People are following this question.
