Josep morancho avatar image
Josep morancho asked
Correct VE Bus cable/device for Multiplus 1200 VA inverter/charger
I have a Multiplus 1200 VA inverter/charger and i need to configure some parameters using the VIctron Connect software
This inverter/charger has 2 rj45 ports inside and i do not find the right ve direct cable required.
Could you tell me what is the right VE direct cable required to connect the inverter/charger to a computer?
Thanks
VE.Bus
wkirby avatar image
wkirby answered ·
You need a MK3 USB interface adapter for that. Use a normal UTP (Ethernet cable) to connect the MK3 to one of the RJ45 connectors inside the MultiPlus.
https://www.victronenergy.com.es/accessories/interface-mk3-usb
