leonvdv1707 avatar image
leonvdv1707 asked
Victron mppt 100/50 charge controller 12/24 selection not working
After short circuiting the output and applying a voltage exceeding 7V on the input (solar panel) the charger does not switch from 12 to 24 V. I followed the steps in the manual, but is does not work. The fault message reads charger or PV over-voltage. The charger has never been connected to a computer or Color control panel. What can be done to change it from 12 to 24 volt as the system was working on 12V before.
error
leonvdv1707 answered ·
Problem solved thank you
Hello @leonvdv1707
Thanks for reporting back, could you please also explain how you solved the problem to help others in the future who might have the same issue?
