I have asked the battery dealer & 14.4v charging is appropriate but I just want to confirm this charger will charge an AGM battery for it doesn't have an AGM mode but does have a 'normal 14.4v' mode so I am hoping I can use this?
Thanks in advance
Thanks in advance
Hi @JohnF
Yes, this should work fine. I don't think the selectable modes are particularly well named, perhaps a little Victron-centric, and consequently confusing. I use a gel preset for my floodeds, but it does what I want.
And you can tweak the presets to personal preference. It will change it's name to 'user defined' or something if you do that. But will work for you..
12 People are following this question.
