jejochen avatar image
jejochen asked
Making net tied Pv inverter work with ESS on AC disconnect
System: 3x 5 kVa multiplus II in 3 phase, 2 current meters, 48 V lifepo4 battery, batrium BMS
I tested the system today, i flipped the main switch to disconnect from the grid. The appliences kept running, but while i thought the PV inverter would remain running, it switched off. I guess it has something to do with sync or so? Please some advise. It is not a must, but would love to keep this running in case of net failure...
Multiplus-IIESS
AC PV inverters are supported, but require some configuration and proper system design to work correctly.
The first step is to read this AC PV document - https://www.victronenergy.com/live/ac_coupling:start
Do you have a system wiring diagram?
Who set the system up and did the configuration for the AC PV inverter?
