I want to connect a 48v DC generator (Integrel) and shore power to the charger. Will this charger accept two charging sources? Would not have both running at the same time.
you can have several charging sources, however, they should all be connected to the battery, not to the charger. Only 230V 50/60Hz should be connected to the chargers input.
It should also be no problem, to use both of them at the same time. They will support each other, just in case.
Regards,
Markus
3 People are following this question.
