ulrichpa avatar image
ulrichpa asked
MQTT Channels for Openhab usage
I' got an Innovenergy Salidomo Battery running which is VRM Victron controlled. In addition, I'm using a Raspberry Pi to control different devices depending on temperature and motion activity. All is running on Openhabian 2.5+. To get access to the VRM data such as SoC of the Battery, AC usage etc, I activated in the VRM remote console the MQTT option. With my MQTT Broker on the Raspberry Pi I get quite a lot of channels coming from the Victron BMS with real-time data of almost everything I was looking for. However, I'm struggling to find the PV Power channel (Solar power coming in from my solar plant), which was apparently available under the stateTopic = "N/a0f6fd5aa8c8/system/0/Dc/Pv/Power" on previous VRM firmware's. My Victron is running on firmware v2.42.
Has the channel name changed or is it not available anymore?
Many thanks
MQTT
