frans-verkooijen avatar image
frans-verkooijen asked
How works the alarm function on the Battery Balancer?
We are applying the battery balancers for the first time. And they are working well. The only thing what is unclear is how the external alarm light and reset button should work. We apply the balancers in a 48V system.
Has the alarm light on the battery balancer the same function as the external alarm? Is a reset button necessary? And When should a customer using the system getting in action after having an alarm on his system?
Kind regards, Frans
Battery Balancer
Warwick Bruce Chapman avatar image Warwick Bruce Chapman commented ·
I think @M.Lange has answered the question well but as a matter of interest, what leads you to say they are “working well”.
What are you monitoring to reach this conclusion?
frans-verkooijen avatar image frans-verkooijen Warwick Bruce Chapman commented ·
Dear Warwick,
Thank you for your reply.
We are measuring the voltage per battery and they are all on the same level. That is why we know the balancers are doing their job.
Regards, Frans
frans-verkooijen avatar image frans-verkooijen commented ·
Dear M.Lange,
Thanks for your reply.
What is not clear to us:
1. The data sheet does not explain the difference between the alarm on the balancer and the one you can install separately.
2. If there is no difference. The alarm on the balancer stops automatically. What is then the use of a reset button?
3. In which situation the customer (user of the system) should get worried about the alarms?
Kind regards,
Frans
Matthias Lange - DE avatar image Matthias Lange - DE ♦ frans-verkooijen commented ·
1. The datasheet says "The alarm relay closes when the red LED switches on and opens when the red LED switches off." so in my opinion that should be clear.
2. If you connect a flash beacon or a beeper or whatever to the alarm relay, you can stop the flashing/beeping/whatever by pressing a push button connected to the reset terminal.
That also stands in the datasheet.
3. If the alarm is permanently on or short after start charging/discharging you should check the batteries separately because one maybe has a problem.
frans-verkooijen avatar image frans-verkooijen Matthias Lange - DE ♦ commented ·
Dear M. Lange, Thank you for your explanation. All is clear know.
Kind regards, Frans.
