micka49 avatar image
micka49 asked
list of utp cable and vebus quick configure
I have : 1 x quattro 48/8000/110 + Fronius Primo 6.0 + grid meter ET112 + CCGX + 1 batt Li BYD b plus L 3.5 (more capacity later)
montage's option : parrallel PV - single phase
With the program VEbus Quick configure, on the step "select required setup", what is the choice for 1 quattro on single phase ? I have only 2 multis ou 3 multis ?
Is it possible to configure the quattro with the CCGX without the software ?
the adaptator MK3-USB between CCGX and Laptot is always necessary ?
About the DATA connectic : - 1 cable VECAN/CANbus typ A between CCGX and Batt + 1 normal UTP cable between Quattro and CCGX + 1 normal utp between datacard Fronius and Webbox + 1 normal UTP between CCGX and Webbox >>> is it correct ?
many thanks for the answer
merry Christmas
micka49 answered ·
i have forgotten : how does the ET112 will be log on ? with the CCGX ? which type of cable ?
boekel avatar image
boekel answered ·
With just one inverter, you don't need VEbus Quick configure, jou can use VeConfig for that.
You can use the CCGX to configure the unit, but please take care: standard settings in the multi might charge to a too high voltage for your batteries.
Also, you might want to update the firmware on the quattro before you begin setup (especially for ESS systems), that is only possible with a MK2/3-cable directly to a windows computer.
the ET112 needs a rs485-usb cable to connect to the CCGX
Cabling: make sure you don't connect to the wrong ports: VE.bus to VE.bus, VE.can to canbus, ethernet to ethernet.
For your battery make sure you have the correct CAN cable, might have different pinout. rest of the cables is normal (patch) RJ45.
Also: CAN-cable, don't use shielded cable as that would undo the galvanic isolation of that port.
micka49 answered ·
Many thanks Boekel
yes, batt Li BYD B plus L3.5 are new ! It's possible that the firmware isn't enough updated.
In summary :
- CCGX VEcan port to Batt Li CANbus port with a the special UTP cable (original VE)
- CCGX VEbus port to VEbus port of Quattro with normal UTP cable
- CCGX usb port to RJ45 port of ET112 (RS485 protocol) with the special RS485/usb cable
for Quattro's firmware update : USB port of PC > MK3-adaptater + UTP cable > VEbus port of Quattro
thanks
