If so, is it ok to go with a 50am even if I will mostly plug into 15amp shore?
(We will have 200ah lithium @24v and 1600w solar)
They run about $200-300. From what I can tell the multi 24/3000 will handle a low voltage (brown out) by switching over.
If I install a breaker box on the input and ran a 60 amp breaker, that should cover ground, open neutral faults as well as over voltage.
Or am I missing something?
13 People are following this question.
