shawn avatar image
shawn asked
BMV 700 History
how to get my BMV 700 to show actual low Battery volts instead of 0.000 when I check the history
solar
adev avatar image
adev answered ·
Is there something in your system that is disconnecting your BMV from your battery every day/night?
shawn avatar image shawn commented ·
no the system is running day and night but it should be able to show the lowest my battery volts drop to instead of 0.000 , its recording my highest battery volts ,
adev avatar image adev shawn commented ·
yes I agree, just wondering if something is making it disconnect momentarily and hence the 0.0 reading is technically true. I don’t have a BMV but had some days in the history where something similar happened on my battery voltage - was because I disconnected battery for system alterations.
When you install the BMV, the lowest voltage always is 0, you have to reset the history.
Devaughn Tyler avatar image
Devaughn Tyler answered ·
How is your setup put together
