saman-daneshvar avatar image
saman-daneshvar asked
DC DC Converters
I have some questions regarding selecting components for a research project. Is there any way I can speak with a technical expert from Victron?
Additionally, I read that Victron does not manufacture Bidirectional DC/DC Converters. We are considering using the following topology and would like to know if it can receive commands from any protocols to transfer power in both directions.
Thank you,
Saeed
system design
Justin Cook avatar image
Justin Cook answered ·
Those are not bidirectional. You're correct (though the photos threw me off) that the top unit would need to be a 24/12, and the bottom unit would need to be a 12/24; that will work fine, but of course they don't communicate with each other so they'll function independently. They do not have data comms at all so they will not be able to directly receive any sort of command - but they do have a remote switch port, so you could probably use an external commanded relay to switch them as necessary.
For more details, the user manuals and datasheets are available directly on Victron's consumer-facing site: https://www.victronenergy.com/
Or you can contact your local authorized Victron distributor for assistance in product selection: https://www.victronenergy.com/where-to-buy
