Josep morancho avatar image
Josep morancho asked
how to restart AC output when battery voltage is normal again?
Hi, I have an inverter/charger Multiplus 1200/230 installed in an off-grid solar system. When the battery voltage level goes low the AC output is sttoped and I have to turn off and on the inverter to get again AC output when battery is charged and voltage level is normal.
Is it posible to restart automatically the AC output when the battery voltage level reaches again the normal value? How?
Is it possible to change the battery voltage values to stop and restart AC output? How?
Thanks
wkirby avatar image
wkirby answered ·
Use VE.Configure software to set your Voltage limits for Inverter shutdown and restart Voltages.
