mfred68 avatar image
mfred68 asked
Is this normal in ess mode
Why is there always a bit of grid power used, (the red bit on top of the blue battery consumption) , it mounts up during the day. Is there a way to stop this in ess mode?
ess discharging
sean avatar image
sean answered ·
Grid inport/export will never be zero, but you might be able to minimise import by adjusting the grid set point.
mfred68 avatar image mfred68 commented ·
So basically this is normal? I jave already tried setting the setpoint from 0 to -50 but it still drifts into the positive and takes from the grid, quite frustrating.
Duivert NL avatar image
Duivert NL answered ·
As sean said, it will never be zero, but put it slightly higher then -50w would help, you need to experiment whit it
Mine is on -100w and i never use grid unless necessary
