windnsolar avatar image
windnsolar asked
CCGX Wrong SOC Calculation
The CCGT do not range the percentage correctly to the voltage. It stays between 84 % to 100%. Causes low voltage shut down despite voltage 51 or higher. Quatro 5000 where ccgt sensor connected Quatro. Voltage shown correctly in CCGT. It is only the percentage not related to voltage. What can cause this disalignment?
markus avatar image
markus answered ·
You mean CCGX?!
Do you have the correct Ah Value set for SOC calculation? This could be done on Quattro with an MK3 interface cable.
