jameshoare1964 avatar image
jameshoare1964 asked
Multiplus BMS Battery volts are 53V but the SMRT MPPT is in Abrorption
Hello could anyone advise/help why the battery volts are well in what should be bulk charging, but the yellow light shows absoption and poor charge levels. Worked fine for 18 months
The Screen says external control, so assume the BMS/Multiplus is setting charge regime,
48volt charging
