Hi Network,
I'm running my setup from Home assistant using the Victron Add-on. It works fine if it comes to control charging. Does anyone know which parameter i have to use for controliing discharging.
Help appriciated
Best Leon
Hi Network,
Help appriciated
Best Leon
...simply set the grid-setpoint to a negative value. If there is feed-in from PV, add this amount to the desired discharge value
73 People are following this question.
