Why has Victron not chosen to certify their equipment to MCS standards? It makes it near impossible to get SEG payments in the UK.
MCS product standards cover PV modules and PV mounting equipment, there is no MCS specific requirement for the other components in a typical Victron system (inverters, batteries etc).
The only products Victron make that would need to be MCS certified are their PV modules, but given they are not targeted at the residential market it's understandable they haven't gone through the process as it is a fairly significant undertaking (factory audits etc).
Check out this thread:-
https://community.victronenergy.com/questions/131033/uk-ess-self-install-mcs-certification.html?childToView=276335#comment-276335
The MCS certification is more about the "installer". You could approach an MCS certified installer and insist on a Victron inverter to be fitted? Or you could go down the self-install approach and join Octopus who do have a route for non-MCS systems that meet their criteria for feed-in payments?
40 People are following this question.
