guru77 avatar image
guru77 asked
Force MPPT to DC grid feed-in
Hi!
is there a way to force the MP2 to feed in to grid, before DC charging battery?
feed-in
matt1309 avatar image
matt1309 answered ·
With node red/adjusting grid setpoint yes.
Otherwise i'm not aware of a way of enabling this. (if you find out let me know).
I can share node red code for this if helpful.
nickdb avatar image
nickdb answered ·
You can just set the setpoint to be negative in the ESS menu on the GX directly.
If you want to schedule this then you would need to use node-red or MQTT to push the value required at the time required.
guru77 avatar image
guru77 answered ·
perfect. thank you!
