AC ESS System with Lithium Battery
This is decided by the BMS and the Victron system only receives the signal of the imbalance, the GX device does not make any decision about if a cell is imbalanced based on voltage.
It cannot be changed on the Victron side, and in most cases I would expect it can’t be changed on the BMS side either, unless it’s a very customisable BMS.
41 People are following this question.
