phynnegator avatar image
phynnegator asked
Working USB mifi device no longer recognized after v2.33 firmware update
I just installed my CCGX and was pleased to discover that my wifi access point, when plugged into a USB port, appeared under Ethernet and got right online. Then I updated the firmware to the current version (2.33) and now the device is no longer recognized (Not "plugged in"). Was this change intentional? If so, is there a way for me to revert to the version that shipped with my CCGX? My access point does not have an ethernet port and I'd always opt for a wired connection, at least to the device, whenever possible.
wifi
Hi, yes there is a method to install older firmware. Use the offline way (ie usb or sdcard) method of installing. All old firmware is here:
http://updates.victronenergy.com/feeds/venus/release/images/
And also there is a backup copy of orevious firmware; still on your ccgx. See Settings -> Firmware -> Backup
And no, no intentional changes. Sometimes we add a newer linux kernel and related drivers into a Venus OS update, and that could be the cause of this.
