Randy Goodman avatar image
Randy Goodman asked
Credentials Message
I ran a flow accessing NR via vrm on my window11 box connected to my cerbogx. How can I from my w11 laptop correct this message? Thx!!
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
security
Randy Goodman avatar image Randy Goodman commented ·
I seen some references to updating a file on the NR system(cerbo). How do I access this file to make any changes?
Anybody know how to access the files on the cerbo? Or better question, should i do what the message suggest at all?
Anybody out there?
