happycloud avatar image
happycloud asked
Dual multiplus and parallel batteries offgrid - check my wire/fuse size please
Working on a dual multiplus 3000/24/120 system (pdf attached) and I think I have the wire and fuse sizes ok but due to the dual nature of the Multis as well as the parallel batteries Id appreciate a look over. Also not totally sure on the size of the Blue Sea DC disconnect. The 6006 is rated to 900 cranking amps so should be fine yes? Thanks! Appreciate any improvements you can suggest.3 Line.pdf
system design
3-line.pdf (768.1 KiB)
