Hi there,
I am trying to source an inverter for my aluminium sailboat that will be compatible with the use of a floating DC system, i.e. where neither battery poles are grounded to the hull. This requires an inverter where the AC ground is not internally connected to the negative DC input. The absence/presence of such a connection appears to be relatively poorly documented no matter the manufacturer - in the case of Victron the only mention I was able to find in any manual is the below screenshot. Unfortunately this does not help me, as I am looking for an inverter with > 1.5kW output.
I would be most grateful if you could provide me with a list of Victron products where the protective earth conductor of the AC outlet is not connected to the negative wire of the DC input.
![screenshot-2024-03-08-at-170046.png](/storage/attachments/72443-screenshot-2024-03-08-at-170046.png)
