Gordon Scriba avatar image
Gordon Scriba asked
Signal K will not remain open
Updated OS Large (3.22) and I have Signal K toggled on. I've reviewed ssh and find the following...
"signalk-server: up (pid13278) 11 seconds, normally down"
I've restarted the signal k server several times resulting in the same message though with varying seconds noted, never more than 20 seconds. Can someone provide some direction? I have spent hours searching the internet for a solution. Signal K and Cerbo worked well for about a year before this difficulty. Thank you in advance.
cerbo gxSignalK
Hey Gordon, most likely your data partition is full. See here:
https://www.victronenergy.com/live/venus-os:large#disk_space_issues_data_partition_full
and after fixing the disk space issue, make sure to check that the signalk server option to flush the log files; or just not log at all, are enabled.
those log files are not necessary for any normal user.
Matthijs
