Which DC to DC charger do I need for a 100 amp van battery with 400ah of leisure batteries? Also what size fuse between do I need between charge and leisure batteries? Do I need a fuse between van batteries and charger?
Thanks,
Mel
Thanks,
Mel
You'll need to work out how much power is available from your alternator and how much the van electrics use. Rule of thumb is to aim to keep the charger plus electrics draw below half the alternator output.
Then you need to do the maths on the loads on the house bank and make sure you have enough charging available based on your expected driving time per day. You may need other charging - solar, grid, generator...
You have a large output leisure battery bank.
Try looking at the 12/12-30 non-isolated charger. But all the warnings apply and you should check this out properly with a competent dealer/installer.
40 People are following this question.
